Dipping my Toes in 64-bit LabVIEW
I recently got a new Laptop to replace my aging XPS.  Of course I installed LabVIEW on it, but to keep things "simple" and use a little less SSD space, I chose to only install LabVIEW 2021 (32-bit), plus the other Bells and Whistles that I use, including LabVIEW Real-Time, cRIO, and LabVIEW Vision.
I've been using 32-bit LabVIEW since LabVIEW 7.0, at least (in part) to be compatible with my colleagues, and because I didn't "need" the 64-bit memory space.  But as I now have a nice shiny (and uncluttered) new Laptop, I thought it would be a good time to venture into the LabVIEW-64 world, which would allow me to see if I should anticipate any problems as LabVIEW "transitions" to a 64-bit model.
Can I just go to the Web Site and say "Install LabVIEW 2021 (64-bit)?  I'm assuming that the other components (Real-Time, FPGA, Drivers, Add-Ons) are installed for both 32 and 64-bit versions (I recall seeing mention of both during Installations and "Un-Installations", but please correct me if I'm wrong.
I'll follow up (after some advice) with How It All Went.
Message 1 of 9
(1,984 Views)
I installed 64-bit LV yesterday. Did it through NIPM. No issues with the install or the app I needed it for.
Don't know about Real-time and FPGA, but other components could be checked and unchecked to install, just like usual.
NI recommends 32-bit unless/until you know you need 64-bit. More info here:
knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIctSAE&l
I never needed 64-bit until yesterday when an old app loaded a large data-file with a not so efficient home-made file format and ran out of memory...
Certified LabVIEW Architect
Message 2 of 9
(1,976 Views)
The https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIctSAE&l article is from 2019.  See https://www.ni.com/en-us/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-application... for an article from 2021.
Since 2019 we have been using 64-bit as the default.
LabVIEW FPGA development has been supported in 64-bit LabVIEW since 2018; interfacing goes back further.
R Series and cRIO do not have 64-bit support but FlexRIO and RF devices do.
ALE Consultants
Message 3 of 9
(1,962 Views)
Real-Time is supposed to have 64-bit support as of LabVIEW 2021.  I am not sure what targets are supported.
FPGA has a very limit subset of targets that are supported in 64-bit LabVIEW.  As far as I am aware, this is a driver issue, not LabVIEW.
There is an effort in NI to push everybody to 64-bit.  I get questions fairly often from NI about why I am not using LabVIEW 64-bit.  My current response is "cRIO support".
Message 4 of 9
(1,960 Views)
Message 5 of 9
(1,920 Views)
Thanks for the comments.  As it happens, two "targets" I'm working with are the myRIO (for which the latest "Toolkit" is still 2019, though a 2021 version is rumored to be released in Q1) and the sbRIO (which, I'm assuming, is similar in requirements to a cRIO).  Maybe I'll build a VM and try doing the installation there (though getting access to the RIOs may prove "interesting", even problematic ...).
Can you say "LabVIEW 2022 Beta"?
Message 6 of 9
(1,902 Views)
I'm fairly sure that won't work.  You might be able to install the runtime engine, but from my testing on a RT cDAQ I couldn't install DAQmx, VISA, or really any software in MAX other than the basics.
Message 7 of 9
(1,894 Views)
I have been using 64 bit as my primary version for several years now and it works great. Granted, I don't use RIO's much so it's not a problem there.
I switched because I couldn't get the Office toolkit to work in 32 bit anymore and haven't noticed a difference. The only time it's been an issue is once when I needed to do some shenanigans with a direct memory address access Xnode, and it didn't work with 64 bit.
Message 8 of 9
(1,873 Views)
Once upon a time, some of the primitives compiled erroneously in 64-bit LabVIEW, but that was ages ago.  It's been around long enough that I'm sure those kinds of bugs are long ago taken care of.
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(1,859 Views)
