sudden stop of File writing
Hello Together,
I've searched the Forum but didn't find any solution, so here's my Issue:
I'm having a quite large QMH which logs every change in an Logfile via Logfile VI, which is a small modification from the Boiler example
(sorry for not posting the whole VI, as this is very large)
Problem:
suddenly the VI Stops wring during writing:
(see incomplete content)
stopped during writing the time stamp
or
stopped during writing the name
I use this VI ONLY within Cases of the message handler loop, so the VI can't be called parallel:
at the end of the Logfile VI I save the refnum back in the MHL Custer, whereas the information is kept in a shift register
previously I had similar problem were my consumer loop was sending very much queues within a short time, but I fixed this with smaller delay, but this problem is new.
I'm additional confused, as the Logfile VI can't called parallel and the error line is passed through the vi, and the refnum is forwarded.
maybe the problem is located by fast acces and Windows accessing the file, but I don't know how to check this
any suggestions?
LV 2015, SP 1
Win 10 Enterprise,
Intel Core 7, 3GHz, 16.0GB RAM
Message 1 of 27
(2,851 Views)
Where does that file refnum get closed?  I'm guessing it closes as soon as any of your loops stops.  It would then be possible that the file was closed right when the Write File function was called.  We would need to see a lot more of your code to do a proper diagnosis.
Message 2 of 27
(2,832 Views)
the "close file" is only in the exit Case:
as mentioned before, the refnum is in the cluster which gets stored in the shift register in the MHL Loop
Message 3 of 27
(2,829 Views)
additional: the access to the logfile is only within this VI, nowhere else
and within this VI the refnum is stored back in the cluster
Message 4 of 27
(2,822 Views)
@WWolf78 wrote:
Problem:
any suggestions?
LV 2015, SP 1
Win 10 Enterprise,
Maybe it's not a sudden stop?
Maybe it a sudden accumulation of the small delays causing you a big delay?
(Can't see the code so can't comment).
but if the delay is based on the ms timer 😉 you'll have the potential for some great fun if you're not careful (about every 50 days after PC restart).
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 5 of 27
(2,809 Views)
Hi James W,
sorry, I'm too deep in my code, so I missed explaining this issues:
for my logfile and the user I regularly send messages to the MHL, like this one:
by communicating to an external system I get 1 message every 20ms, which I read and storage within an array:
last Time I had an Message VI within this  loop, which caused the previous error.
Solution thereby was to put an Message before and after the "data acquisition" loop and adding smaller delay in this way:
so no delay which could accumulate..
Message 6 of 27
(2,792 Views)
How do you limit the log file size?
~~~~\Oh, magic 8-Ball, does the sudden stop happens when the log file hits 2Gb?~~~~~
It is decidedly so.
"Should be" isn't "Is" -Jay
Message 7 of 27
(2,780 Views)
there's no limit but it seldom exceeds 5mb:
the system creates an logfile on every start, even for tests, so some files are 2kb.
the longer tests (with the failed writing) are the larger ones, but stil between 2-5mb
Message 8 of 27
(2,776 Views)
If the reference is first stored in a VI that stops running, the reference will become invalid. Even if the buffer never stopped running.
Any (native LabVIEW) reference becomes invalid when the top level data space where it was created stops running.
A quick hack would be to test the reference, and reopen the file if the reference became invalid. Or to simply always open\write\close...
Message 9 of 27
(2,770 Views)
I'm guessing that your timer eventually gets out of sync with your messages and you start catching only parts of the message.  Might want to re-think your communications - e.g., if the messages come in every 20 ms, just wait for a message instead of trying to sync with the message timing.
Bill
CLD
(Mid-Level minion.)
Message 10 of 27
(2,762 Views)
