Digital Outputs
I'm trying to figure out how to set all of my digital outputs on my DAQ to the off position until I assign a port and a line. Can anyone help me with this please?
Message 1 of 9
(4,030 Views)
Your program cannot talk to the hardware until you assign the port/line.
Why are they on by default??? Was it from a previous run? Maybe you should do a proper shutdown procedure to ensure that all are off before the program ends.
Message 2 of 9
(4,020 Views)
Accepted by topic author Abby242
Depending on the model of the hardware, you can Setting and Reading the Power-Up States of Digital Output Lines.
Message 3 of 9
(3,968 Views)
We definitely need to know more about your problem, because we can't really tell that you are talking about the power up state or some undefined state while the device was still powered up by your program did not terminate correctly or crashed in the previous run, or you aborted it instead of doing a proper shutdown.
Message 4 of 9
(3,938 Views)
Can you please attach your code?
Message 5 of 9
(3,934 Views)
What for?
Message 6 of 9
(3,929 Views)
Just trying to see if I can help. I would like my answer to be accepted as solution.
Message 7 of 9
(3,926 Views)
I think I got it figured out.
Thanks!
Message 8 of 9
(3,796 Views)
Thanks!
When you know you have it figured out, it would be helpful if you posted your solution (and mark it as the solution) because I think this would be a big help for others who might be struggling with the same problem as well.
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(3,776 Views)
