Digital Outputs
I'm trying to figure out how to set all of my digital outputs on my DAQ to the off position until I assign a port and a line. Can anyone help me with this please?
Message 1 of 9
(3,795 Views)
Your program cannot talk to the hardware until you assign the port/line.
Why are they on by default??? Was it from a previous run? Maybe you should do a proper shutdown procedure to ensure that all are off before the program ends.
Message 2 of 9
(3,785 Views)
Accepted by topic author Abby242
Depending on the model of the hardware, you can Setting and Reading the Power-Up States of Digital Output Lines.
https://tmesystems.net/
Message 3 of 9
(3,733 Views)
We definitely need to know more about your problem, because we can't really tell that you are talking about the power up state or some undefined state while the device was still powered up by your program did not terminate correctly or crashed in the previous run, or you aborted it instead of doing a proper shutdown.
Message 4 of 9
(3,703 Views)
Can you please attach your code?
Message 5 of 9
(3,699 Views)
What for?
Message 6 of 9
(3,694 Views)
Just trying to see if I can help. I would like my answer to be accepted as solution.
Message 7 of 9
(3,691 Views)
I think I got it figured out.
Thanks!
Message 8 of 9
(3,561 Views)
Thanks!
When you know you have it figured out, it would be helpful if you posted your solution (and mark it as the solution) because I think this would be a big help for others who might be struggling with the same problem as well.
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(3,541 Views)
