Showing results forĀ
Search instead forĀ
Did you mean:Ā
Digital Outputs
I'm trying to figure out how to set all of my digital outputs on my DAQ to the off position until I assign a port and a line. Can anyone help me with this please?
Message 1 of 9
(3,892 Views)
Your program cannot talk to the hardware until you assign the port/line.
Why are they on by default??? Was it from a previous run? Maybe you should do a proper shutdown procedure to ensure that all are off before the program ends.
Message 2 of 9
(3,882 Views)
Accepted by Abby242
Depending on the model of the hardware, you can Setting and Reading the Power-Up States of Digital Output Lines.
Message 3 of 9
(3,830 Views)
We definitely need to know more about your problem, because we can't really tell that you are talking about the power up state or some undefined state while the device was still powered up by your program did not terminate correctly or crashed in the previous run, or you aborted it instead of doing a proper shutdown.
Message 4 of 9
(3,800 Views)
Can you please attach your code?
Message 5 of 9
(3,796 Views)
What for?
Message 6 of 9
(3,791 Views)
Just trying to see if I can help. I would like my answer to be accepted as solution.
Message 7 of 9
(3,788 Views)
I think I got it figured out.
Thanks!
Message 8 of 9
(3,658 Views)
Thanks!
When you know you have it figured out, it would be helpful if you posted your solution (and mark it as the solution) because I think this would be a big help for others who might be struggling with the same problem as well.
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(3,638 Views)
