Derivative of arrays
I am new to labview and this question might seem trivial to you.
Here is what I am trying to do:
I have two arrays (generated via for loops).  I want to calculate the derivative of array 1 with respect to array 2 and then plot the resulting array vs array 2.
My VI (attached) does not do what I am trying to do.
Please help.
(10,777 Views)
It's hard to tell what you are trying to do.  You gave no defaults for C and C2, so I entered 20 and 30.
You threshold the B array at 70 to get a value of 6 (that means that value 70 should be at index 6 in the table, which it is).
You're then using 6 as the dT input to the derivative function.
What do you expect to see and what do you see that's wrong?
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(10,769 Views)
Accepted by efi
The dt is typically the difference between the x-values (function assumes that the x-values are equally spaced, which they are). So, to get dt, simply thake the difference between any two adjacent x-values.
All you need is a single loop, right? The formula node seem overkill, for example the division by two should be done once before the loop.
Here's how you could simplify... makes sense?
(10,763 Views)
Sorry for not being clear.  Do not pay attaention to the numbers I used, they are just for example.  The problem I have is general; I want to get the derivative of one array with respect to another one.
In particular, I want to generate array A and B (as I did via forloop), get dA/dB and plot dA/dB vs B.
I am guessing I might even have used a wrong function for derivative... please advise
(10,760 Views)
OK, here's where you lost me. Usually you get the derivative with respect to a CONSTANT, not another signal.  dT = sampling rate is a common one.
If what you want is truly dA / dB, then delete one element from array A, subtract the original array from the shortened array (that calculates A[1] - A[0], A[2]-A[1}, and so on: an array of delta-A).
Do the same thing for the B array. to get deltaB
Divide deltaA by delta B.
Steve Bird
Culverson.com
LinkedIn
(10,755 Views)
thanks a lot. that is exactly what I was looking for...
(10,752 Views)
Thanks. This is what Christian showed nicely in the avove jpeg. file
(10,747 Views)
