‎05-29-2009 10:48 AM
Is there a way to delete channel data that has already been written to a TDMS file?
Just writting the new data tot channel data appears to append the new to the old.
I don't see a way of deleting OR replacing the old dat with the new.
Ben
‎05-29-2009 11:46 AM
There isn't a way. Options you have:
‎02-22-2011 05:49 PM
‎02-22-2011 05:59 PM
In LabVIEW 2010 look under File IO>>TDM Streaming>> Advanced TDMS.
This might contain what you are looking for.
Hope this helps.
‎04-06-2011 06:32 AM
Nope, still seems like there isn't a way to do it.
‎04-07-2011 12:03 PM
Hi markza,
Check out this example and see if it is what you need:
http://decibel.ni.com/content/docs/DOC-5735 (Delete single TDMS Channel from an existing TDMS File)
Have a great day,
Chris
‎04-07-2011 12:57 PM
Thank you Chris but...
You should go explain to Jarod why his solution count just went down by one. ![]()
Ben
‎04-08-2011 01:42 PM
You know what's sad, Ben, is I was the one who wrote those TDM -> TDMS and TDMS -> TDM conversion VIs that the poster used in the example to delete a TDMS channel.
‎04-08-2011 02:55 PM
All is not lost.
Repost with a link to the same solution. That way I can mark your new reply so new users will find the example with a double bonus of you re-taking that solution and picking up some more Kudos along the way.
Go for it!
Ben
‎10-15-2011 09:34 PM
Can you upload detail explanations of new TDMS functions in LabVIEW 2011 or 2010?
I am considering the upgrade for TDMS function.
Labmaster
