Decoding IRIG signal
Hello everyone !
I have a cRIO-9074, and I'm trying to decode an IRIG-B signal. I have the module NI-9402 for input.
I know that there is an example here http://www.ni.com/example/28396/en/, but it is old, for a PXI and it doesn't work with the last version of Labview...
Does anybody have an example which work, or a begining of an answer?
Thanks !
Simon M
PS : sorry for my bad english
Message 1 of 9
(5,522 Views)
When you migrate the code, What kind of problem do you have?
I can share with you another example (non official, and I do not supported this code) but you could use it.
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
Message 2 of 9
(5,484 Views)
hello !
Thank you for your answer !
The problem is there are some connections which are not possible. I think the software has evolved and  now, and the connxions are note available because it's not the same types of data...
I will see your code !
Simon M
Message 3 of 9
(5,429 Views)
Oh ! This example seems to work ! All the connections are okay.
Thank you verry much ! I will try to study the code to configurate my cRIO now.
Simon M.
Message 4 of 9
(5,424 Views)
can you please publish the example?
Message 5 of 9
(5,294 Views)
Which one do you want?
Samuel G. | GEMESIS
GEMESIS.EU
Message 6 of 9
(5,273 Views)
You wrote “I can share with you another example (non official, and I do not supported this code) but you could use it.”
I would like to see a working code for IRIG-B Decoding in Labview
I am checking an option to record IRIG-B signal with audio card along with some events and then to synchronize different sources offline.
Message 7 of 9
(5,260 Views)
Hello, you could find the code in attachement of my last post (05-28-2014 10:03 AM).
Samuel G. | GEMESIS
GEMESIS.EU
Message 8 of 9
(5,241 Views)
I sounds like you got this working for the NI-9402.  Did you just use his latest code (and update the signals for your hardware)?  Did you have to make any other changes?
Phil
Message 9 of 9
(4,799 Views)
