Maximum cDAQ throughput
Hi there,
If I have cDAQ 9179, full with 14 NI 9220 C Series Analog Input Module, would it be possible to acquire continuously the full 448 channels (32*14) at a sample rate of 100kS/s ?
If no, what are the limitations ?
Thx,
(3,335 Views)
Start by calculating what that requires for throughput. Look at the maximum throughput for your transmission bus.  Are you over or under that?
(3,305 Views)
Thank you for the "A-B>x" answer...
I don't know what it requires, that's why I'm asking. 9220 is an analog input module, so it give double numbers.
I don't care of the throughtout of the USB3.0, what I want is to be sure the cDAQ itself coupled with DAQmx will do the job, with no exception.
Any NI application engineer here ?
Thx
(3,300 Views)
Accepted by topic author PragmaTest
448 channels 100,000 kSa/s 16 bits per point (2 Bytes per point)
448 x 100000 x 2 = 89.6 MBytes/sec
Can your system keep up wit that rate?
mcduff
(3,294 Views)
