Data read using CAN (PCAN), XNET
Hi all,
I want to read the data using CAN cable for 5 min then after 5 min it should stop and log it to the excel file.
I am new to this CAN I don't know what to select and all.
want to read like this <Value.png>
using:
LabVIEW 18
Peak CAN to USB Cable
Ni-XNET Driver
I have attached all the documents.
Message 1 of 31
(4,215 Views)
Hi Basavaraj,
@Basavaraj093 wrote:
using:
Ni-XNET Driver
Simple answer: you cannot use the NI-XNet driver for a PeakCAN interface. XNet only supports hardware from NI…
Suggestion: use suitable drivers for your PeakCAN interface! There are lots of threads in this forum about PeakCAN…
Message 2 of 31
(4,197 Views)
Thank you for your reply,
what you said is true.
I am trying to search it but couldn't find any drivers (LabVIEW).
Please share you have any information about it.
Thanks in advance.
Message 3 of 31
(4,187 Views)
Hi Basvaraj,
a simple search for "peak can labview driver" gives this result
Message 4 of 31
(4,181 Views)
Yes and No. Yes, XNET hardware driver won't work, but you can use XNET library with PCAN to manage your CAN frames and signals. See
http://hooovahh.blogspot.com/2017/03/can-blog-introduction-and-downloads.html?m=1 for this.
By using XNET after PCAN's read your code will be more reusable.
CLA
Message 5 of 31
(4,175 Views)
I have searched it already, but it is not free.
is there any driver which is free to use.
Message 6 of 31
(4,167 Views)
PCAN basic is free.
Also see this post about a .net version I created.
Good luck!
Message 7 of 31
(4,142 Views)
Yes, it is free but
how to use it in LabVIEW.
Message 8 of 31
(4,132 Views)
You need to learn usage of .NET in LV then. Refer to https://blog.dmitriev.de/labview/net/netframeworkcorestandard/
for valueable introduction into this topic.
CLA
Message 9 of 31
(4,119 Views)
Without it we can't receive CAN data?
I want to just Read\Receive whatever coming from the CAN cable.
is there any other method?
Message 10 of 31
(4,109 Views)
