Data logging rate
I am a complete noobie and trying to record thermocouple data using Signal Express 2012.  I can get the data to record and export to a text file, but it is recording at 1.1 seconds.  I would like to change it to once every second, but don't see that option anywhere on the record options.  Thanks for any help!
Tom
Message 1 of 10
(6,073 Views)
Hi Tom,
maybe you should ask in the SignalExpress forum?
Message 2 of 10
(6,064 Views)
In your configuration tab you should see Sample Rate in the lower right corner.  This is what determines how often to collect assuming your set to 1 Sample On Demand.  If the sample rate is set to faster than 1.1 seconds then your hardware may be the limiting factor.
Message 3 of 10
(6,053 Views)
Oh yeah, sorry didn't see that forum at first.  Thanks.
Message 4 of 10
(6,048 Views)
Thanks, but I'm guessing that doesn't apply to Signal Express since I don't see a configuration tab anywhere.  I'll post in the correct forum.  Thanks!
Message 5 of 10
(6,045 Views)
I am using Signal Express 2012.  My sample rate was defaulted to 100mSec and it collected that fast when connected to my USB-6351.
Message 6 of 10
(6,039 Views)
How did you get that window?  I'm using version 6.0.0 and when I click on Recording Options tab I can change signal selection, start stop conditions, events, etc. but I don't see where to change the rate.  Thanks:-)
Message 7 of 10
(6,033 Views)
Hi tbsmith,
at first you post in the wrong forum, now you say you're using an old version of SignalExpress - which you should have told right in the beginning...
And NI doesn't know about some SignalExpress 6.0.0 as is shown here...
Message 8 of 10
(6,017 Views)
Accepted by tbsmith
6.0.0 is the current version of Signal Express 2012 which is what I have.
I just opened SE, selected Aquire Signals > DAQmx Aquire > Analog Input > Temperature > Thermocouple.  Then I selected a channel from my 6351 and the Configuration tab popped up like in the picture I posted.
If you're new to SE open the manual:  Help > Getting Started With...  It's a quick doc (50 pgs.) but it explains everything quite well.
Message 9 of 10
(6,002 Views)
Thanks NIquist, that did it!  Also good to know there is a manual included in the help file.  Appreciate the help in getting me going!
Message 10 of 10
(5,989 Views)
