‎02-07-2019 04:40 AM
Hi dhananjay,
2. I believe so yes, LabVIEW does have access to the folder. I have mapped the drive to the pc using network map drive.
No, sorry, no TeamViewer possible here.
‎02-07-2019 04:46 AM
what do you mean by labview on my cdaq?
I've connected the cDAQ to my pc itself using LAN, and added it to the same project on which the VI is running.
‎02-07-2019 05:28 AM
Hi Dhananjay,
what do you mean by labview on my cdaq? I've connected the cDAQ to my pc itself using LAN, and added it to the same project on which the VI is running.
Your cDAQ9134 has an embedded controller and is able to run VIs "on its own".
So it is important, which host is running your VI:
‎02-07-2019 06:05 AM
windows pc is running the VI but I'm saving the file onto the external hard disk connected to the chassis(ni-9134)
‎02-07-2019 06:26 AM
‎02-07-2019 08:45 AM
When the VI is executed within the cDAQ then it will have NO access to your PC's harddrive.
because of this reason?
‎02-07-2019 09:00 AM
