I2C on a cDAQ
I have seen the Whitepaper regarding I2C modules but they seem to be strictly for FPGAs.  Is I2C a possibility with cDAQs?  I could definitely see that being a "no" seeing as how the code is all remote.
(2,597 Views)
Hi Dose,
apart from your question: you might use an Arduino as a cheap I2C-to-COMport bridge…
(2,543 Views)
I am a big fan of the USB-845x devices from NI, which can handle SPI and I2C as well as some additional DIO.  A little on the pricey side, but they work beautifully.
I have also had success using a VirtualBench as an I2C master, assuming you also need a DMM, oscilloscope, logic analyzer, power supply, and/or more DIO.
(2,539 Views)
@GerdW wrote:
Hi Dose,
This was actually one of the ideas we've put into our AoA.  Arduino/Pic.  But we only want a single controller.  So if I got with Micro option, then no cDAQ.  And I'm personally falling in love with the idea of all code being on the remote machine.
(2,529 Views)
Definitely considered these, but for our needs, not enough DIO.
(2,528 Views)
