Data Logging to a .csv file
I have attached a file that creates an array of 32 string values. Each value are headings - temp1, temp2, temp3 etc. Then I gave wired the array to a Write Delimited Spreadsheet. I was hoping all 32 values will come in different cells in the spread sheet files, i.e in all in 1st row but different columns. But I  am getting all values in 1 cell, i.e row 1 column 1. How can I make it in separate columns.
Message 1 of 10
(7,583 Views)
Hi govind,
unfortunately you attached a LV2018 VI which I cannot open right now.
But this one works as requested:
Do you know the meaning of "CSV"? It's like "comma seperated file"…
- Do you use the comma as separator character in your VI?
- Does Excel (or whatever you use to open that CSV file) also expect the comma?
- Excel will also tend to use other chars as well, like TABs in txt files or semicolon for CSV files…
Message 2 of 10
(7,570 Views)
Its ok you dont have to open my file, because it is 100% nonsense what I have done. But can u please give me the name of the vi inside the for loop.
Message 3 of 10
(7,560 Views)
Hi govind,
you know I attached a snippet?
Why don't you look for yourself?
Message 4 of 10
(7,552 Views)
Its format into string. But I am still not getting it in different columns. I use the delimiter as a comma in the write delimited spreadsheet, but then when I run it, all the values are coming in the same cell, but there is a comma at the end of each value. I also used a write to text file and gave the file name as .csv.  In the write to text file, I am getting it in different cells, but then i am getting in different rows and same column, but what i want is same row different columns. Please help me how to correct one of the above or both.
Message 5 of 10
(7,546 Views)
Hi govind,
Please show a snippet of your VI.
And please explain how you "run" the CSV file (or better: which tool do you use to examine its content?)!
Using the right tool will show your CSV file with different values in different columns…
Message 6 of 10
(7,540 Views)
Accepted by govindsankar
You can fix it with Text to Columns in Excel. Some regions (especially countries using decimal comma) use semicolon as separator instead of comma.
So, try either using ";" as separator or fix it in Excel afterwards with Text to Columns.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 10
(7,539 Views)
Thank you. I didnt know that. Using semicolon as delimiter worked. That was the problem. Thank You very much.
Message 8 of 10
(7,534 Views)
Hi govind,
Did you read message #2?
Message 9 of 10
(7,530 Views)
/Y
I have found it best to use the tab as the delimiter and then save the file as a .txt.  Excel tends to open it right up with no issues for me.
Message 10 of 10
(7,526 Views)
