DAQ Reference Design missing svc_Engineering_Units to Unit Label.vi
When loading Data Acquisition Reference Design.lvproj from daq_ref_app_v10.zip into LabVIEW 9, LabVIEW to Find svc_Engineering_Units to Unit Label.vi file.
I have already loaded all of the packages listed in the Software Requirements section of Data Acquisition Reference Application for LabVIEW and DAQmax.
There is no such file in my system. There is no such file in daq_ref_app_v10.zip or in the directories that it created.
Where can I get svc_Engineering_Units to Unit Label.vi so that I can load this project?
Thanks.
(2,848 Views)
Try taking a look at the search dialog screen. It usually gives you a clue as to where it wanted to find a file. If you did not find it by searching, I suspect it is inside an llb.
Ben
(2,844 Views)
I couldn't find a svc_Engineering_Units to Unit Label.vi that it was asking for but I could find _Engineering_Units to Unit Label.vi. When I substiuted the latter, LabVIEW issued a notification that the dependency had been changed. Ihope that the two are the same.
I wish that NI would update the refernce design so that it would run without error once all of the conditions in the Software Requirements were met.
(2,826 Views)
