Ring control & case structure
In my ring control 3 or more items are there and is connected to a case structure each item having each frame. If I select second item then the case structure should run both 1&2 frames. And if I select third item then the case structure should run 1,2&3 frames and so on. Is it possible?
"Thanks with regards "
by
..........Gireesh..........
(3,003 Views)
Accepted by topic author gireesh
This is not possible with simply a Case Structure. Place a For Loop around the Case Structure, and loop either 1, 2, or 3 times by wiring the ring into the Count Terminal, and wire the Iterator Terminal to the Case Selector.
(3,002 Views)
OK, Thank you I will try
by
(2,995 Views)
