Copy config to another pc
I need to copy configuration from one computer to another computer - both running Windows 2000 pro. Not sure if they're both using the same version of LabView.. I think they're both LabView 7 Express?
Anthony
Message 1 of 18
(4,373 Views)
hi there
what kind of configuration do you mean? if you mean the labview config (menu->tools->options dialogbox) then simply copy the labview.ini file from the \labview x.y directory. you then should restart labview.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 18
(4,355 Views)
I tried copying the labview.ini file and this did not work.
I get two errors after running the .vi file... These errors do not occure on the other computer using the same file, same device and same card. Is there a way to copy all configurations?
Thanks for the help!
Message 3 of 18
(4,345 Views)
hi there
error 8 means that you don't have access rights to a file. but this error shouldn't occur with the LabVIEW.ini file (then you'd see the dialog box shown in the attachment). i bet there's another user-config file. search for this file and grant the user read/write access rights or turn on the debugger and search for the origin of the error.
Best regards
chris
Message 4 of 18
(4,335 Views)
How do I turn on the debugger? This error happens when logged in as a local administrator as well.
Thanks!
Anthony
Message 5 of 18
(4,332 Views)
hi there
please refer to the "Running and Debugging VIs" section from the LabVIEW "VI, function & How-To Help".
Best regards
chris
Message 6 of 18
(4,330 Views)
Hi Cytokin,
It seems you have issues with the NI-488 drivers. Are you communicating with any instrument using GPIB ? Verify that NI-488 is installed on the second computer.
I will appreciate if you can provide more information on your application and the hardware setup for further troubleshooting.
T.A.
Message 7 of 18
(4,310 Views)
Tunde,
If you saw the pictures that I posted... I fixed the one mentioning the file opening (the file was read-only) but I did not fix the other error.
I can not answer your question, because I am only an IT Technician... The person who uses this asked for my help and I honestly don't know what I am doing with it 🙂
How do I check if the instrument is using GPIB? How do I verify that NI-488 is installed AND if it is not, how do I install it?
I really appreciate the help! Thanks!
Anthony
Message 8 of 18
(4,305 Views)
Hi Anthony,
Can you post the labVIEW code to have an idea of the setup. Otherwise I will suggest you conatct the developer for more information.
Also, make sure all National Instruments software installed on the first PC are installed on the second PC (especially the NI-488.2). To verify this, go to Add/Remove Programs->National Instruments and click on "change" button to display all the National Instruments software installed. If NI-488.2 is missing on the second PC, you can download the latest version from (https://www.ni.com/en/support/downloads/drivers/download.ni-488-2.html).
Regards
Tunde
Message 9 of 18
(4,285 Views)
I installed NI-488.2 and it still does not work. I get the same error.
Thanks!
Message 10 of 18
(4,270 Views)
