ā11-12-2010 09:32 AM
I have an x-y plot that lets you choose the data you want displayed.
All I want to do is make an exact copy of it so that I can plot on two different scales.
I really cannot figure out how to do this since I didn't write the original program.
I don't know if anyone will be able to help, and I'm not even sure how useful posting the program will be because there are a lot of subvis.
The actual plot is in the 4 main frame and 4 subframe and 1subframe in that.
Thanks.
ā11-15-2010 03:02 PM - edited ā11-15-2010 03:02 PM
Hi Kat,
I'm happy to try to help out, but there are a bunch of VIs in that zip file. Which one is the top level VI? I'm not quite sure what I'm looking for here. Thanks!
ā11-19-2010 10:27 AM - edited ā11-19-2010 10:27 AM
I am really sorry I completely forgot to mention that.
It's the 6 Channel HP vi.
ā11-22-2010 01:31 PM - edited ā11-22-2010 01:31 PM
Hi Kat,
Thanks for clarifying that. This code is pretty complex, and not really laid out in an easy-to-follow manner. The current plot is dynamically modified all over the VI by property nodes, so unfortunately you can't just copy and paste a new graph in the program.
At the end of the day, I think adding a second identical graph with a different scale would be a whole lot of work because of how this program is set up. However, if you create a new graph and modify it anywhere the existing graph is being modified, you should be able to accomplish this. I'm sorry I don't have an easier solution for you.
