MS Visual C++ error when launching LabVIEW 8.6
I'm using a PC (running Windows XP) which has LabVIEW 8.6, 2009, and 2010 installed on it.  When trying to launch 8.6, I receive this runtime error:
If I click OK on this window before the Getting Started screen initializes, I close LabVIEW.  However, If I wait until after the Getting Started screen appears, the window above becomes inactive and unusable.  I haven't tried much programming or poking around, but as far as I can tell LabVIEW behaves normally (I can open and create projects and VIs).
Has anyone run into this before?  Any insight would be great.
Adam Fern
(3,010 Views)
so this Runtime error doesn't stop or effect LabVIEW if you ignore it, and if you click ok it will close LV down. Are the other versions of LV working?
(2,980 Views)
Yes, 2009 and 2010 work without any problem.
(2,973 Views)
Accepted by topic author theflyingmtneer
Try reinstalling the LV 8.6 runtime engine
(2,944 Views)
