Error 56 TCP open
Running LabView 10 on windows 2000.  I have made several vi's communicating with a Thermotron chamber with a 3800 controller via TCP. Static IP address all around.  The vi's in stand alone run fine. They initialize the chamber, set run manual, set set point for temp, read temp, control aux. The problem result when these vi's are called from a program as a sub vi.  I then get error 56 the network operation exceeded the user-specified or system time limit.
(3,352 Views)
It would help if we could see a screenshot, or even better, the actual code. Is the subVI wired correctly? If something isn't wired up, you may not be setting the IP address or port to what you think you are setting it to.
(3,348 Views)
The IP address, port and command is all in the sub vi. How does one send the code in here?
(3,339 Views)
Ok attempting to attach a zip file of the code.
(3,336 Views)
