09-21-2005 09:04 AM
09-21-2005 11:05 AM
09-21-2005 12:56 PM
Thanks a lot SeaDevil for your great effort!
Your third part gave me some good hints how to do the actual conversion from bin to 2 hex digits.
Concerning the timer solution: my special problem with the captured data is that the clock signal is not constant, with the consequence that I have to trigger the data reading on every rising edge of the clock signal.
Are the trigger functions for waveforms in Labview 7.1 better than in 7.0?
Since in 7.0 they seem to work only for analog data waveforms. Or what other possibilities do I have to trigger on a digital signal?
e.g. the array search function allows to search only for a single element. To look for a transition from 0->1 I would have to use 2 nested searches, which is imho quite time consuming, considering I have a few thousand samples.
Thanks in advance,
Tryber.
09-21-2005 01:19 PM
