09-20-2005 01:30 PM
09-21-2005 02:36 PM
Hello cherrafito,
You can do this very easily with LabVIEW and NI-DAQmx. If you set up an analog input temperature task, the DAQmx driver will acquire the voltage from your 6008 and automatically scale those voltages to temperature values based on what type of thermocouple you are using. Please take a look at the shipping examples in LabVIEW. Click on Help >> Find Examples... In the Example Finder, browse to Hardware Input & Output >> DAQmx >> Analog Measurements >> Temperature.
Any of the Thermocouple examples should work for you. Let me know if you have any further questions.
Sean C.
