08-11-2009 10:17 AM
08-11-2009 11:41 AM
Hello Squinn21,
After looking at your VI, it appears that you have the exact same wire going into each of your thermocouple wires. While dynamic data types do have a certain amount of "magic" assoiated with them, they will not automatically split their value between multiple indicators. Instead, try using a "split signals" to separate your channels. When you're done your code should look something like this. Hope this helps!
10-26-2009 11:44 PM
I have been following this posting and I have the same issue as the originator. I have build the VI to match the diagram as provided, but when I attempt to split the signal from the DAQ Assistant data output, I can only wire from one terminal on the output of the splitter. My DAQ assistant in set up for measuring 16 thermocouple channels from two SCXI 1112 boards installed into a SCXI 1000 chasis. The A/D is accomplished using an SCXI 1600 board also installed in the Chasis. When I run my VI only the first channel works. I have the data terminal wired from the DAQ Assist to a Write to File Experss VI with a dynamic data wire. When I save the data to a file, I can see that all 16 channels are about the same as the 1st (small variations) even when I have only 1 or 2 themocouples connected. It seems as though the DAQ Assistant only outputs a single channel.
10-27-2009 12:11 AM
OK... I found in another posting that I needed to expand the splitter up and not down in order to create multiple terminals. With that done I could wire each split from the data output of the DAQ assist to an individual numeric indicator, but they all still read the (approximate) same value! If I raise the temperature on one thermocouple, all indicators rise. The data written to file show the same results. Even those channels without a thermocouple connected read and respond the same.
