PCI 6230 digital trigger to start analog output and input
I recall reading somewhere on the KnowledgeBase that not all boards can send out an analog output when triggered with a digital trigger (please correct me if I'm wrong).  Can someone confirm that the PCI 6230 can indeed send out an analog signal by using a digital trigger.  I've been trying to get an analog output signal to be triggered by a digital trigger and I've had no luck.  However, I have had luck creating a digital trigger to synchronize the analog inputs.  Can anyone help?
My VI structure is as follows (using stacked sequences):
Layer 0:  Create digital output channel that will send the a digital signal out of the digital output terminal 0.
Layer 1:  Create analog output with digital (rise edge) triggering (from digital input terminal 0).
Layer 2:  Write [0 1 0] array to digital output channel.
(The digital output terninal and digital input terminals are wired together)
I appreciate any help.
Robert
(3,259 Views)
Please delete this post.  I have found some help.
(3,245 Views)
Could you please post your solution here to help out anyone else who may run into this issue.  Thanks!
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(3,232 Views)
I wish I could give some insight on the exact fix.  I decided to go with someone else's code that had a different architecture to accomplish the task.  It is possible with the card above to achieve what I wanted (synchronized input and output).
(3,224 Views)
