Check to see if a string is "close enough" to what is expected
I have a silly question which I think I know the answer to but I am wondering if someone has tackled this.
What I am after is an algorithm that looks at text that is entered (or coming from one source) and compares it from another source. Now, this text might have an extra space, a dash, or even misplaced words but the algorithm says "yeah, that is what the user is looking for."
Is what I am asking not possible? My scenario is data coming from two different sources looking at the same data, which may be slightly off, but neither system knows about the other.
I have an example VI below but I am at a loss on how to implement what I want.
Message 1 of 15
(2,292 Views)
I believe I may have a solution. A simple Google search for "check that two strings are close enough" came up with the  Levenshtein Distance Algorithm to implement into my VI.
Message 2 of 15
(2,273 Views)
Looks like a few people have been down that path; maybe you won't have to run your own!
https://forums.ni.com/t5/LabVIEW/String-similarity/td-p/1332452
https://lavag.org/topic/22309-string-similarity-in-g/
Message 3 of 15
(2,249 Views)
Message 4 of 15
(2,234 Views)
I'll admit...I like being challenged so, I decided to tackle this via the website I posted.
I am having difficulty deciphering this piece of the Java code:
for (i = 0; i<=n; i++) {
p[i] = i;
I think it is just placing numeric values into an array. Is that correct? Attached is the LV code (2021) plus I copied the code from the website into a comment box.
Message 5 of 15
(2,193 Views)
Paul - I am not sure if yours would work. Maybe I am just looking at this from the website I posted but aren't you comparing the two words character for character?
Message 6 of 15
(2,189 Views)
p[i] = i;
I am not used to Java programming (actually, I've never programmed in it before) but it's just a For Loop incrementing one digit to the p array, correct?
Message 7 of 15
(2,160 Views)
No.  It's recursive and correctly implements a Levenshtein Distance Algorithm.
Message 8 of 15
(2,149 Views)
@Eric1977 wrote:
p[i] = i;
Here's the equivalent LabVIEW code:
Message 9 of 15
(2,146 Views)
@paul_a_cardinale wrote:
@Eric1977 wrote:
p[i] = i;
Is there a '+1' missing between the control 'n' and the 'N' terminal of the for loop?
Message 10 of 15
(2,123 Views)
