write one tdms files in 2 producer consumer loop
I want to write data in tdms file. I have 4 loops which is 2 producer and 2 consumer. I need to write the data in same tdms file in two groups. How can i do it?
test Vi is attached so idea should be clear
(377 Views)
(376 Views)
Try the attached modification.
Here is a snippet:
Necessary Changes:
Open TDMS Reference before loops start.
Close TDMS Reference after both loops complete.
Recommended Change:
Use Share Stop Signal VI to stop all loops while only requiring a single Stop button
If you need to eventually span multiple files  due to file size or just duration of test, you will need a more sophisticated approach.
Good luck!
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(341 Views)
For those that may not be familiar with Share Stop Signal VI, it ships with LabVIEW and can be found here: <LabVIEW>\vi.lib\ChannelSupport\Share Stop Signal.vi
It is not in the palette, and I don't think Quick Drop finds it, but it is still a handy utility for cases like this.
Doug
(292 Views)
Thats a nice tidbit of information to put in my back pocket. Thanks
Joe.
"NOTHING IS EVER EASY"
(271 Views)
