String similarity
Do you know any functions, packages, addons... for calculating string similarity? (such as Levenshtein distance, etc.)
(4,655 Views)
I think you have to build these functions on your own..Using string functions available.
See this example of "Levenshtein distance"....
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,647 Views)
See here in the LAVA CR for an implementation of the levenshtein distance.
Felix
(4,643 Views)
LAVA version works. gak's VI sometimes doesn't. Compared with PHP's Levenshtein function
(4,616 Views)
May be, I just gave an example as in how you can use string functions available in labview to fulfill your purpose.Smiley Happy
Gaurav k
CLD Certified !!!!!
(4,582 Views)
