Check if file exists returns false. File is in system32
I'm having a problem detecting if a file exists which was simply copied to the system32 directory.  I tried moving the file to various other directories and simply using a vi with the "Check if file or folder exists" action.  I've narrowed it down to not being able to find the file if I copy it to either c:\windows or c:\windows\system32.
I thought this could be a permissions issue, but did my best to assign the user name full control of the folders.
Another interesting thing is if I make the file input a control and click on the "folder" icon to open a list of files, I cannot see the newly copied files in system32 directory either.  Very strange.
This is on a Dell PC, Windows 7 professional/Labview 2010 SP1 (note I am running the vi. as an executable on this machine).  Could it be some setting in my project build?
(4,600 Views)
Accepted by topic author dre99gsx
If you're using Windows 7 64-bit, it may be related to the problems the user was having here:
http://forums.ni.com/t5/LabVIEW/Problem-Using-quot-msg-quot-command-with-quot-System-Exec-vi/m-p/153...
It may be that the LabVIEW functions are 32-bit and are getting redirected.
(4,595 Views)
Thanks!  Put the files in syswow64 and suddenly it sees them.  I guess it was redirecting from system32.
(4,589 Views)
