取消
显示结果
搜索替代
您的意思是:
Changing a property of a string indicator in a cluster with a sub-VI
已解决!
转到解答
I know the question of updating an indicator on a top-level VI from a sub-VI has been asked before on the discussion board, but my question is slightly different because I want to update the property of an indicator, not necessarily its value.
In my top-level VI I have a cluster which contains some string indicators.  The cluster is a typedef.
I want to change the background color of the string indicator to red or green from my sub-VI so that it looks like this:
Creating a reference to the cluster and passing it to the sub-VI doesn't seem to work.  I'm not able to see the Text.BGColor property to change the background color of the string indicators:
It seems like creating a reference to a string indicator and passing it to the sub-VI might work like this:
Is there a better/more elegant way to do this? Do I have to create a string reference for each string in my cluster and pass it to my sub-VI?
I messed around with global variables, but no luck.
Plese help.
0 项奖励
1 条消息(共 9 条)
7,943 次查看
what I think you left out in that question is the step where you take the cluster ref and get the refs to the objects inside the cluster. Since there is more than one and cluster allow different data types, the refs from the cluster ref are generic and the property you are looking for is specific to the strings.
So what you need is the "To more specific" node along with a constant ref for a string and you should be good to go.
I wrote about this idea in my Nugget on Exploiting Control References where I discover at run time the definition of the cluster. Don't worry about reading and understanding everything in that nugget. Just read enough to figure out what need to change in your code.
Ben
2 条消息(共 9 条)
7,933 次查看
解答
已被主题作者 Sidd 接受
You have the right idea.  The cluster reference has a property called Controls[].  That returns an array of references to every control in your cluster.  Indexing those will have the BGColor properties you need.
3 条消息(共 9 条)
7,928 次查看
Thanks.  Your solutions worked.  Here's the working sub-VI:
0 项奖励
4 条消息(共 9 条)
7,906 次查看
Hey,
I'd really like to do what you have shown in the 2nd image where you have the Numeric Indicator changing colour dependant on value. I'd like to create a NUmeric Indicator that is green if a value is in spec. or red if it is outside of spec.
Please can you tell me in laymans terms how to do this? I'm a somewhat beginner on LabVIEW anyways.
Craig
0 项奖励
5 条消息(共 9 条)
7,141 次查看
@RotoMoto wrote:
Hey,
Craig
How about this? Background is green when the number is between 90 and 100, otherwise red.
=== Engineer Ambiguously ===
0 项奖励
6 条消息(共 9 条)
7,132 次查看
Looks perfect, thanks, though I'm not sure where I find each of the functions used?
Sorry total layman at the moment.
0 项奖励
7 条消息(共 9 条)
7,123 次查看
They are in the functions palette吐舌表情
I hope you know how to create a numeric control (x) and the numeric constantans
In Range and Coerce is in Functions--->Comparison
Select is also in Functoins--->Comparison
The Color Box Constant is in Functions--->Dialog and User Interface
The NumText.BGColor Property Node is created y right clicking on the numeric control terminal on the block diagram and from the popup menu select
Create--->Property Node--->Numeric Text--->Colors--->BG Color
Then right click on the Property Node and select Change All To Write
0 项奖励
8 条消息(共 9 条)
7,093 次查看
That worked perfectly! Thanks a lot.
Craig
0 项奖励
9 条消息(共 9 条)
7,075 次查看
