How to calculate Day of Year
Is there a quick and easy way to convert the Day of month, Month and Year to Day of Year?
Message 1 of 21
(9,691 Views)
you can use get date/time string.vi and date format should be set to long
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 21
(9,685 Views)
Convert a timestamp using the 'Format into String' function and a format of  %<%j>T. If you need the number, then convert the output using 'Decimal string to Number'
Message 3 of 21
(9,681 Views)
Yet another way.
Message 4 of 21
(9,675 Views)
Or you could use Format Date/Time String, with the format string set to %j
Message 5 of 21
(9,602 Views)
Hello, how do I do this for with the current time.
Message 6 of 21
(8,452 Views)
Use the Seconds to Date/Time function and unbundle the Day of Year.  Do not have an input for the Seconds to Date/Time node as it defaults to the current time.
Message 7 of 21
(8,443 Views)
Thank you 🙂
Message 8 of 21
(8,432 Views)
how do I get month of year? is there any vi to get that?
Message 9 of 21
(7,918 Views)
Same way as CrossRulz mentioned in his post.
Look at the Help for that function.  It has numerous outputs that could be useful for you.
Message 10 of 21
(7,907 Views)
