Change tabs with buttons
Hi Everyone
I have 5 tabs:
tab1 = user tab (which will contain 4 buttons: button 1, button2, button3, button4)
When button 1 is pressed tab 2 screen is user interface
When button 2 is pressed tab 3 screen is user interface
When button 3 is pressed tab 4 screen is user interface
When button 4 is pressed tab 5 screen is user interface
I tried to do this using Boolean buttons so when the button is pressed it will change to the correct page is there a better way to do this?
Ailish
(4,400 Views)
It could work if you code it correctly.
For an alternative look for the "Radio buttons" since they already have the multually exclusive behavour built in.
And yes the radio buttons can be customized to look differnt if you want.
Ben
(4,399 Views)
I use this method quite a bit, within a state machine, attached is a basic example..
Cheers
(4,392 Views)
I have labVIEW version 10 an its not allowing me to view your VI.
Ailish
(4,375 Views)
(4,368 Views)
