Change CAN Frame Data Length Parameter
The issue is that there is no clear way of supplying the DLC within the Cluster.
Message 11 of 22
(2,115 Views)
What about using the Bundle/Unbunlde Cluster functions?
Have you worked with clusters before?
Message 12 of 22
(2,111 Views)
The CAN Frame cluster used within the NI embedded CAN for RIO only provides 4 controls. They are Identifier, Extended?, Type and payload. None of these controls correspond to the DLC field.
Message 13 of 22
(2,108 Views)
Hi yousif,
I'm working with CAN modules in a cRIO and use the FPGA to exchange CAN messages.
The driver for CAN modules within FPGA provides all fields as needed:
Message 14 of 22
(2,096 Views)
Edit to my last post:
The CAN modules can use an array of 6 U32 values to transmit a CAN message. In the next image you see how the CAN cluster converts to this U32 array:
(The byte ordering stuff is added by me as I use an U64 instead of an U8 array to hold the CAN message data.)
The main point here is the way how IsRemote? and DLC are packed into one U32 value…
Message 15 of 22
(2,091 Views)
Have you even tried communicating with the equipment yet, or has this all been a theoretical discussion about what may or may not work?
Now would be an excellent time to upload the equipment user's manual.  DLC will not be exposed to the user when sending because it is a calculated value.  Just like you won't find CRC exposed either, because it's calculated when you send the message.
I think you're all hung up on the data size.  The data cannot be MORE than 8 bytes but it can even be zero.  Just try sending the message itself without worrying about DLC and see if it works.  I'm (reasonably) sure it will.
Bill
CLD
(Mid-Level minion.)
Message 16 of 22
(2,090 Views)
Oh and sorry to leave you hanging.  It was almost midnight local time.  😄
Bill
CLD
(Mid-Level minion.)
Message 17 of 22
(2,087 Views)
I am not using the regular NI-CAN library. I am using the NI embedded CAN for RIO because my board, the sbRIO 9651, is not supported by NI-CAN. The only access to a CAN Frame is through the provided cluster:
Message 18 of 22
(2,074 Views)
Accepted by yousifd
I'm guessing you can bundle your payload as an array of three bytes?  (Or however many you actually need.)
Bill
CLD
(Mid-Level minion.)
Message 19 of 22
(2,067 Views)
Thank You Bill. Your method worked. I just wasn't sure of how to change the array size in the cluster but I figured out that you can delete array elements from the front panel and that would change the array size.
Message 20 of 22
(2,034 Views)
