Is there a simple way to display a number in the most logical unit?
Hi, often I'm taking a measument in a VI and displaying it in real time in my front panel. Often, the range of the measurement changes drastically in a short timespan. What I'd like is for it to display it in the simplest units. So for example, if the measurement is in volts, and it's currently 2E-8, I'd like it to say 20 nV instead. Now obviously if I wanted it to always be in nanovolts, I could just multiply the display by 10^9, but sometimes it will quickly go from nV to mV or something, and I don't want it then displaying 3E5 or something.
So what I'd really like it to do is have it automatically adjust to use the "closest" unit. I know I could do this using some logic statements or maybe a Ring, but that's kind of clunky. Is there a more efficient way to do this? thank you.
(3,296 Views)
Do you know the display format properties?
Try SI- notation Format 🙂
Rigth-Click on the indicator, choose Display Format..
Greetings from Germany
Henrik
LV since v3.1
(3,279 Views)
Accepted by topic author optoelectro
Set the display format to SI notation.
(3,278 Views)
One addition:  Add a log, fixed scale bargraph for a quick optical view!   Since m,µ,n,p mix up quickly 😄
Henrik
LV since v3.1
(3,272 Views)
Awesome, exactly what I want!
(3,255 Views)
