Case Structures
Hi i need some help with case structure. The input that i wired gives me a TRUE value. Thus, my boolean for the TRUE case structure does light up. However, one of my boolean for the FALSE Case structure also lights up and i am struggling to understand why since my inputs give a TRUE value. Please help and keep in mind i am new to Labview
(1,655 Views)
(1,651 Views)
Accepted by MBSHIRAZIZ
Probably the values in the false case retained there old values. Once set to true, executing the false case won't make them false.
You probably want to put all 3 indicators outside the case, so all 3 values are set to a value regardless the case.
But it's not obvious what you actually want by just looking at code that doesn't do what you want.
(1,645 Views)
okay thank you.
(1,549 Views)
