Can typecast create error?
I am retrieving data from a database, consisting of an array of 4 bytes. The expected value from the database is 15000000000.
When I typecast the array to a single, somehow the value I end up with is 15000000512.
I have verified the data from the array by converting them to Hex (50 5F 84 76) and converted it using the online converter https://www.scadacore.com/tools/programming-calculators/online-hex-converter/ which works fine and returns the expected value of 1500000000.
Can someone help me to understand what goes wrong with the typecast, and how I can convert the data correctly.
Please see picture below:
Best regards
Karsten Jørgensen
Denmark
Message 1 of 12
(7,059 Views)
I didn't experience the same thing using LabVIEW 2019 32-bit.
My numeric values are U8s. Is that the same for you?
GCentral
Message 2 of 12
(7,021 Views)
When I make that VI, I get 15000000000 as expected (not 1500000000, but that's probably a typo).
Either you looked wrong, or you have some hidden error in your code, that can't be spotted from an image.
Post the VI if you want us to have a look.
Message 3 of 12
(7,018 Views)
I checked 16\32 bit integers, but that gives rubbish.
I used LV18 64-bit.
Message 4 of 12
(7,015 Views)
Accepted by karsten.jorgensen
While SGLs are 32-bits wide, 8 of those bits are lost to the exponent, so once you get above 2^24 (roughly 7-digits), you can no longer represent every integer value.  What you are seeing is the closest integer value that can be represented by a SGL, no errors.  Different manifestation of the usual floating-point issues we see around here (large values instead of small).
Use a U32 or I32 instead and you will get the desired value, exactly.
Message 5 of 12
(7,007 Views)
[EDIT: Darin.K beat me to it]
I'm also seeing 15000000512 when using an array of U8's.  LV2016.
Actually, I copied the SGL indicator, made it a control, and fiddled with incrementing.   Sure enough, it looks like a SGL cannot exactly represent 15000000000, so it's stuck giving you one of the near neighbors it *CAN* represent.
-Kevin P
Message 6 of 12
(6,994 Views)
In both 2013 and 2018 I get 15000000000.
A sgl cannot represent all values, no argument there.
But it can represent 15000000000 on my computer. This is pretty well defined in IEEE 754, and should be exactly the same on all computers that use IEEE 754 floating point numbers..
There must be a difference between how your setup and ours.
Can you try the snippet cbutcher posted?
Message 7 of 12
(6,980 Views)
The clever folks at NI try to insulate us from these strange effects with a little trick.  The default Display Format of a SGL is 6 digits.  You need to push that up to see the actual value.
Message 8 of 12
(6,977 Views)
Never mind. Found the problem.
The default display format for a float is 6 significant digits.
So that means only 150000 is displayed, the other decimals are always 0. So it's displayed as 15000000000.
When switching to digits of precision, I get 15000000512.
As expected, but sloppy of the online calculator, that apparently also uses 6 significant digits.
EDIT: That crossed...
Message 9 of 12
(6,976 Views)
Bummer. I increased the display but clearly not enough...
Expected something like the above explanation but was surprised I didn't get the same result. Oops!
GCentral
Message 10 of 12
(6,970 Views)
