Error -200170 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi:1780002
I've been trying to understand this error and researched it in the forum. Even though the physical channel is attached to the device, it still doesn't see it. I tried to add a physical channel to the device but I have no luck on this. I even unplugged the USB from the DAQ device, too. Please help! If need more information please let me know.
(3,792 Views)
Accepted by topic author leomoore16
Have you checked out in Measurement and Automation Explorer (MAX) to see if it exists there and works in a test panel?
Verify the name of the device and module you used matches the device you think you are using?
(3,753 Views)
Under the settings of " NI cDAQ-9174 'cDAQ1Mod1_1' " of NI MAX, I had to change the name to the same name the software uses in order to work. It had too many characters and had to decrease it. Thanks for helping me!
(3,601 Views)
