Can I generate a boolean output whenever I abort a VI?
@Yamaeda wrote:
Hmm, i see i can r-click the word in the reply and choose "don't correct 'word'" so now word should be written as i write it! (yay \o/ )
So it definatly seems like some forum setting/stuff/problem.
It sounds like it could almost as likely be that it is a browser setting.
Bill
CLD
(Mid-Level minion.)
Message 31 of 33
(477 Views)
(from a post a few days ago)
wiebe@CARYA wrote:
Don't forget to check CTRL+.
That still works even if abort isn't visible.
Please correct me if I'm wrong, but for completeness, you can disable Ctrl+. by either
  • Using "Edit>>Run-Time Menu..." to implement a custom Run-time menu, removing "Operate>>Stop", or
  • Using "VI Properties>>Window Appearance>>Customize..." and uncheck "Show Abort button".
So unless you *want* the abort button behavior, either of those will take care of Ctrl+., right?
joeorbob
Message 32 of 33
(456 Views)
Yes.
Or you can Discard key down? events for CTRL+. . That also works.
The first two options can be set\unset dynamically with properties though, but it might not be 100% safe (user might press CTRL+. before the property was set. The events will work, but adds some code that you really don't want.
You can manually override the VI properties in a build spec for an executable, but you'll have to think about doing that for each dialog.
Message 33 of 33
(441 Views)
