how to convert labview g code to c language
is there anyway to convert labview g code to c/c++ language ,include block diagram and front panel , use some labview code to convert , not an .exe toolkit
Message 1 of 14
(4,398 Views)
Message 2 of 14
(4,383 Views)
The obvious response on a LabVIEW forum is of course:
WHY convert LabVIEW g code to c language?
There are several ways to call LabVIEW code from C code...
Message 3 of 14
(4,350 Views)
1. Yes you can convert it. Manually.
2. No ready made one that functions good. Maybe a Project for you?
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 14
(4,322 Views)
I dismissed that option, as OP stated: "use some labview code to convert".
It will need a hole lot of LabVIEW code to convert!
Started that a few times, over the years. It's the pot of gold at the end of the rainbow, but very educational.
Last time with OO, it got quite serious. C++11 triggered that, as it got native threading.
Sadly, implementing the easy 40% of the functionality is 1% of the workload...  In other words, you'll hit a wall at some point.
I got polymorphism working, which was quite exciting.
I got loops working, incl. shift registers and feedback nodes (not timed loops though, hate them).
I got threading working, on VI level.
I got the most common functions working (math, some strings, clusters, arrays).
I could even cross compile to RPi, which was pretty cool.
Scaling up to subVIs, and implementing rest of the functions is a year's work, for 40 people...
GUIs will easily triple that workload.
Message 5 of 14
(4,311 Views)
Yeah i suspect it'll be a black hole of a Project. 🙂
I saw the question as a two parter: can you convert? and is there some automated feature? Thus my answer. Also, it's friday. 😛
Qestit Systems
Message 6 of 14
(4,307 Views)
NI has LabVIEW C Generator Module.  Saw it a few years ago during NIWeek.
Anyone tried that module?
https://www.ni.com/en-us/support/downloads/software-products/download.labview-c-generator-module.htm...
George Zou
Message 7 of 14
(4,285 Views)
I was thinking of mentioning that but decided not to. 😉 It is just for embedded targets (thus no conversion of the UI) and has other limitations, including no support for modern versions and a high price(?). For more information, also read Rolf's comments here.
Message 8 of 14
(4,280 Views)
Related (but offtopic!), the NXG web module will generate "text code" that browsers understand. 🙂
Message 9 of 14
(4,267 Views)
@ wiebe@CARYA@Yamaeda i want to convert g code to c/c++ , and then cross compile it to binary file and run on my arm linux board, including front panel display on LCD . or is there labview runtime could let labview vi directly run on arm linux board ?
Message 10 of 14
(4,219 Views)
