3D bar graph: different color for the bars with different height
Hi everyone,
Do you know a method to set different color for the bars with different height in a 3D bar graph?  I need to draw a 3D color bar gradient graph like the picture attached, please give me some instructions, thanks very much!
(2,630 Views)
The Color and Name property can set colors, but if it's Always the same you can simply click the color box in the Legend to set a color.
Qestit Systems
Certified-LabVIEW-Developer
(2,605 Views)
Hi Yamaeda, Thanks for your answer, but the Color and Name property can only set colors by row, while the bar colors in each row may be different in my case. The problem is the same by clicking the color box to set the color. Am I right? Do you have any other suggestions?
(2,588 Views)
It looks like you are looking for  a 3d scatter plot, with  the ability to change the xyz point style to a column,
which is orthogonal to the XY plane.
With the built-in functionality, I think this is the  closest you can get:
(2,550 Views)
Hi alexderjuengere,
Thanks a lot, it is closer, but what I want is a slender bar from XY plane to top for each data point, while the point of the scatter graph is of a fixed length, looks like some floating points which makes a not very good visual effect.
(2,536 Views)
@SimonChen100 wrote:
Hi alexderjuengere,
take a closer look, those are cubes of fixed sized, the cube's center represents the actual Z value.
you could stack those cubes on top of each other to mimic a column.
that is of course not practically, and doesn't look so well either.
the 3d Stem Plot allows to assign a line to each xyz point, which is orthogonal to the XY plane.
unfortunately, you can't assign a "volume" to this line
(2,508 Views)
Hi alexderjuengere,
I think 3d Stem Plot is better, thanks for your suggestions.
(2,498 Views)
