CR Touch
Hi!
please i need help
i am trying to connect  CR touch probe with myDAQ then use Labview code to get result .
regards
Message 1 of 11
(3,957 Views)
Please do not ask us to do your homework for you.  If you need technical help, please provide more complete information.  Include all of the following:
  • A manual for specialized pieces of hardware ("CR Touch Probe").
  • Explanation of "technical jargon" (what is "Auto Leveling"?).
  • Version (year and whether 32-bit or 64-bit) of LabVIEW you are using.
  • (All of) the LabVIEW code you have developed so far (attach actual .vi files, not just "pictures of block diagrams").
  • Test data if applicable.
Message 2 of 11
(3,945 Views)
Hi alrahal,
@alrahal1 wrote:
please i need help
Which part do you need help with?
Where are you stuck?
What have you tried?
Message 3 of 11
(3,945 Views)
Hi
the code i have used (please see attached file )
but i could not get to arm and disarm the probe .
Message 4 of 11
(3,935 Views)
thank you for your help but it is not a homework and i wrote the probe name that i am using so you can look it up
Message 5 of 11
(3,932 Views)
Hi alrahal,
Is there any error from your LabVIEW code?
Do you get the expected output? Did you verify using a scope?
Message 6 of 11
(3,924 Views)
Sorry, I'll pass ...
Message 7 of 11
(3,908 Views)
the code is working fine and i get a result when i used a servo as test
Message 8 of 11
(3,899 Views)
Hi alrahal,
So what exactly is the problem?
Again I have to ask:
What is the problem?
Message 9 of 11
(3,843 Views)
The problem was with cr touch probe didn’t move ,I don’t know if I am doing something wrong with the code or what I need to change.
The idea is to have the touch probe binning disarm until it’s touch the surface.
it is similar to the idea in 3-D printer or the touch probe in CNC machine.
I appreciate your help
Message 10 of 11
(3,803 Views)
