CLD Practice review
Hi everyone,
I tuned in to the webinar on the CLD exam the other day and they recommended putting up the CLD practice exams I had done on the forums. I'm not sure if this is the one he was referring to, but here goes!
I just ran out of time on the boiler example, but finished the car wash example with ample time left over. Hopefully they work the same for those of you who download them. I've not transferred projects/VIs in this manner before, so I'm a little concerned there'll be conflicts/breaks.
Thank you for your time and patience.
(3,382 Views)
Don't expect the same questions in Exam but practicing these requirement will make you to understand and speed up your coding time which will help you in actual exam.
Try to do the same program multiple times so that you will find how to program in reduced timing.
Going forward you can post your solution for review https://forums.ni.com/t5/Certification/Sample-Exam-Solutions-for-Review/td-p/1824703
(3,343 Views)
Thank you for the advice for pointing me to the forum!
(3,319 Views)
This is basically the first requirement for passing.
If the examiner transfers your code and it doesn't work, you won't pass. Make sure all paths are relative (to the project or VI's).
(3,299 Views)
