06-03-2010 08:49 AM
Can radio buttons be programmatically controlled?
If x happens the radio button X is selected, if y happens then radio button y is selected.
This would occur automatically in the VI.
Solved! Go to Solution.
06-03-2010 09:10 AM
Of course. See the answer to an identical question today.
06-03-2010 09:13 AM
11-02-2017 07:59 AM
Hi I have the same question as the user previously stated. I read the accepted solution and was just wondering if I could get more clarity on the topic as to how to control radio with the enum.
11-02-2017 08:18 AM
Hi Arhakore,
This will work like any other control too: you can set its value by writing to a local variable of the control.
To get the correct enum for your radiobutton you just need to right-click the terminal of this button and create a constant. (Or you just place the typedefinition, which you created with your radiobutton, in your block diagram…
All this is basic LabVIEW stuff so I recommend the free lessons to learn LabVIEW.
