10-05-2018 01:26 PM
Bar Code Scanner connected like keyboard. I can see scanned data on the Front Panel, but can't use it until Enter key pressed.
Is there a way to use it without hitting "Enter"?
Thank you
10-05-2018 01:37 PM
Program your barcode scanner to append an Enter character to the end of the scan.
10-05-2018 02:26 PM
Or you can right click the indicator and select "update while typing".
10-05-2018 02:30 PM
If a value change event is configured for the control, this would cause an event to fire for every letter. This may/may not be desirable.
10-08-2018 06:22 AM
Programming the scanner would be the best, but if that's not possible, update while typing is better then blindly polling the string value.
Of course bar code scanner can often also be read through a (virtual) serial port. Doesn't really change much, you'd still want an enter after each scan, or you'll have to poll data.
10-15-2018 06:07 AM
Thank you. This is good way.
