Arbitrary waveform generation and looping that waveform
Help required, if anybody knows how to loop this waveform continuously! I tried to make this waveform using arbitrary wave generator VI. I am able to make the waveform but cannot loop it continuously.
Help in any form will be appreciated. Thanks!
Message 1 of 11
(4,077 Views)
Hi inji,
You VI is huge and can be simplified like this:
Just output the waveform again. What is the problem?
Message 2 of 11
(4,066 Views)
What are you trying to loop this waveform on?  A DAQ analog output?  A function generator?  Or are you just trying to repeat an operation in software?  We need a lot more context for what you are trying to do with this waveform in order to actually help.
Message 3 of 11
(4,051 Views)
Thank you for replying.
I want to continuously loop the waveform. When the waveform ends, it should start again from the beginning, like all the inbuilt waveforms present in labview.
Message 4 of 11
(4,047 Views)
Hi inji,
No "inbuilt waveform" does "start again from the beginning"…
Create the waveform, then "play" it in a loop.
You still don't explain where you want to play/output the waveform!?
Message 5 of 11
(4,035 Views)
Yes, I tried to loop it using a while loop 😐.
Sorry if I being lame. I want the waveform to repeat periodically. Also, what is the process to change the units of time.
I want to get the output of the waveform using a NI USB 6001.
Thanks again!😊
Message 6 of 11
(4,032 Views)
There's the key information I was looking for.  Luckily for you, there is a DAQmx Write property called Regeneration Mode.  Just set that to be "Allow Regeneration", write your waveform to the DAQmx task, and then start the task.
NOTE: This VI was based on having multiple channels in the task.  Hence why Waveforms is an array.  It will still work with a single (scaler) waveform.
Message 7 of 11
(4,014 Views)
Could you please share the VI file of this?
Thank you so much. I cannot believe of getting such great response in this short period of time.
Keep helping sir!
Message 8 of 11
(3,987 Views)
Save the PNG file to your desktop.  Then drag that file into your block diagram.  If you are using LabVIEW 2019, then you'll have the code!
Message 9 of 11
(3,958 Views)
Sorry, our institution has provided us with the 2013 version. This feature is not working in this version.
Message 10 of 11
(3,945 Views)
