An error occurred while running LVCompare.
Hi, I am struggling with the following error of  LVCompare, does anyone have any thoughts about this?
As far as I understand LVcompare can't create INI file?
I am running LabView 2015 professional under Win10, with win7 everything worked fine but since I migrated to 10 I never seen LVcompare working. Thoughts and suggestions are welcome.
NI_LVConfig.lvlib:Load.vi<ERR>
C:\Temp\LVCompare.ini
<b>Complete call chain:</b>
NI_LVConfig.lvlib:Open Config Data (compatibility).vi
LVCompare.vi
Message 1 of 13
(6,678 Views)
it has been confirmed by NI support that LVCompare does not work for LabVIEW Full development system LV2019 32bit and 64bit. The error you mention is one of the errors seen.
LabVIEW Professional Development system works as expected. You can change version inside NI License Manager - provided you have a license of course.
Message 2 of 13
(6,416 Views)
The original poster said he was using professional and so am I.  I get the same error.
Message 3 of 13
(6,379 Views)
I get that error from an MSYS2 terminal "git diff" of a VI with LabVIEW Professional Development System Version 2023 Q3 (32-bit) 23.3.1f1. C:\Users\<user.name>\AppData\Local\Temp\LVCompare.ini does not exist (I have permissions and can create the file manually). The complete call chain is slightly different:
NI_LVConfig.lvlib:Open Config Data.vi
LVCompare.vi
Message 4 of 13
(4,528 Views)
After closing LabVIEW, "git diff" worked. Interestingly, "dir /s /b C:\LVCompare.ini" says "File Not Found" right after the comparison is displayed.
Message 5 of 13
(4,513 Views)
Do you have your NI installation in a non-default directory?
LVCompare and LVMerge have some paths hardcoded into their code apparently, I've had problems trying to get them to run when I install the tools in directories different to the default ones on "C:\Prog...."
Message 6 of 13
(4,497 Views)
I use default installation folders:
C:\Program Files (x86)\National Instruments\LabVIEW 2023\LabVIEW.exe
C:\Program Files (x86)\National Instruments\Shared\LabVIEW Compare\LVCompare.exe
Message 7 of 13
(4,489 Views)
OK, worth a try, I've had issues with non-default paths and LVCompare and LVMerge just refusing to work unless put back in the default folder.
Are all your other folders also set to default?
Message 8 of 13
(4,485 Views)
Yes; my LabVIEW, Options, Paths look like your screen shot.
Message 9 of 13
(4,481 Views)
Well, that sucks, because otherwise it might have pointed to a possible solution. Sorry.
Message 10 of 13
(4,478 Views)
