Agilent 34410A voltmeter configure measurement current front/real both enable
Hi all,
I want to measurement 2 channel current by Agilent 34410A,how to configure front/rear enable both.
Just search in forum only have 1 channel, any information would be appreciated.
(1,591 Views)
34410A is a 1-channel DMM, the front/back are the same connections internally routed. You need an external multiplexer to switch the signals to DMM or get another DMM.
BTW, all DMMs are 1-channel, some DAQ-like DMMs have a multiplexer/switch matrix card inbuilt to measure multiple signals.
Santhosh
Soliton Technologies
(1,560 Views)
Thank for you reply.
Additional question is when use NI-USB-GPIB Card how to control 34410A from remote to local model. I tried send command as "SYST:LOCAl",doesn't  work and got an error.
(1,456 Views)
Hi Sam,
What "doesn't work" and which error did you get?
(1,451 Views)
34410 LED display "ERROR" still keep remote model .
(1,446 Views)
