Accelerometer G-Force with Labview
Hi eveyone,
I would like to know if anyone knows how to do the g-force graphic at Labview, like shows in the F1: https://www.youtube.com/watch?v=Le-l58gZSfs.
Anyone knows how to do a ball moving like that?
Vitor crepaldi.
Message 1 of 11
(5,222 Views)
Accepted by shockst
This should generate some Ideas:
"Should be" isn't "Is" -Jay
Message 2 of 11
(5,207 Views)
Thanks Jeff,
Could you please, send me the .vi?
Message 3 of 11
(5,196 Views)
Jeff's picture is called a VI Snippet.  If you drag it onto a block diagram it turns into code.
Message 4 of 11
(5,183 Views)
Oh... nice. I didn't know about that.
But could you take the snippet for the labview 2012?  that is the one I'm using.
Regards.
Message 5 of 11
(5,174 Views)
Here you go...
Message 6 of 11
(5,138 Views)
Thank you so much,
That will help me a lot.
Vitor.
Message 7 of 11
(5,131 Views)
NIquist,
Thanks a lot man. With your help I did exacly what I wanted.
Just one more thing. I would like to change the image that the polar plot appears.
Now I'm seeing this one: PolarPlot.png. but I would lik to have this imaga: G-Force.png. Where can I edit that image?
Vitor Crepaldi.
Message 8 of 11
(5,118 Views)
You just need to suply the picture imported from png to the polar plot (and set the grid transparent) Like thus:
The stock vi's add some artifacts that you do not want
But if you save  renameds copies you can safely edit them without breaking anything anyone else is doing.
This small edit is all that is needed:  (and wire picture to new picture through the enabled case)
Make sure yuo save renamed copies of all three of these vis or you will eventually be very sorry
Message 9 of 11
(5,110 Views)
Now it's great.
Vitor.
Message 10 of 11
(5,095 Views)
