A numeric control ignores data entry limits when entry is typed, why?
Data entry limits set in the property box seem to have no effect on data entry. A value written to a property node limits the input from increment buttons but not data that is typed into the control. How do I prevent a numeric control from accepting values outside of desired limits? In the attached example why can I type in any number to the control and the data entry limit is ignored?
Message 1 of 11
(7,181 Views)
Is your response to value outside limits set to coerce?
Which LabVIEW version are you using?
Tim Elsey
Certified LabVIEW Architect
Message 2 of 11
(7,171 Views)
Accepted by mmiers
In the Data Entry properties window for the Numeric control, you have the "Response to value outside limits" set to ignore.  Change it to coerce.
- tbob
Inventor of the WORM Global
Message 3 of 11
(7,170 Views)
I'm using labview 8.6.1. The response to values property was flipping back to ignore when I set it. I restarted Labview and tried again, It seems to work fine now so setting the "response to values outside of limits" property to coerce does solve the problem. Thanks.
Message 4 of 11
(7,142 Views)
I believe 8.6 had a bug in setting the control properties.
Ben
Message 5 of 11
(7,116 Views)
That's why I asked what version he was using.  I think the bug was only with the Properties Window and the workaround was to use property nodes.  Anyway, I think it was fixed in 8.6.1 (is that the same as 8.6.1f1?), which he is using.
Tim Elsey
Message 6 of 11
(7,109 Views)
I don't have fix version memorized but the symptoms were:
First attempt to set a control worked fine.
Second attempt were always bad.
Exit LV and restart, again would work on one control.
Ben
Message 7 of 11
(7,106 Views)
I get the same error.
I have Labview 8.6.1 what do I do to fix the problem?
Message 8 of 11
(6,851 Views)
Which of the above pieces of advice did you follow?  And which aren't working?
Message 9 of 11
(6,823 Views)
Just what we need - more spam.
Message 10 of 11
(6,165 Views)
