Showing results forĀ
Search instead forĀ
Did you mean:Ā
2's complement
Sorry about that...
I think this one should work:
Message 11 of 25
(15,051 Views)
hi again,
your vi works perfect  -  both ways ........... - no comment neccesary.
Werner
P.S. For poeple with   ADC's and Uni/Bip.- mode.... my old styled vi attached with 16 bit resolution
Message 12 of 25
(15,041 Views)
Many times, the 12 bit 2s Complement is not a boolean array, but contained in e.g. a single 16 bit Integer. In this case, you don't need to jump through all these hoops converting to a boolean array, etc.
You can just do the bit operations directly as shown in the attached VI (LabVIEW 7.0). Seems much more efficient. šŸ™‚
(VI is not fully tested, please verify correct operation. You might want to add an error condition if any of bits 13-16 are set).
Message 13 of 25
(15,027 Views)
Here is a modified version of Altenbach's 16 bit Integer version. the same idea as my boolean array version posted above. I think the algorithm is more simple and faster.
Xu
Message 14 of 25
(14,988 Views)
Xu
Message 15 of 25
(14,986 Views)
Nice but you did not drop the sign bit
Message 16 of 25
(11,334 Views)
796
Qestit Systems
Certified-LabVIEW-Developer
Message 17 of 25
(11,325 Views)
my two cents to raise the thread from the dead
works for arbitrary bit sizes
Message 18 of 25
(11,296 Views)
I have attached a 12 bit 2s complement I used for temperature senor TMP100. The Negative numbers are represented in binary twos complement format and has a resolution of .0625C per count.
Message 19 of 25
(11,259 Views)
Is this the same result? No, not exactly.
It's the same except for 0x80012 bit 2th complement.png, that value (-0?) gives a bad result.
Message 20 of 25
(11,255 Views)
