07-23-2016 09:12 AM - edited 07-23-2016 09:13 AM
08-25-2016 10:34 AM - edited 08-25-2016 10:35 AM
Is there someone to help me ?
02-07-2017 04:51 AM
nobody knows ![]()
02-20-2017 10:12 AM
Is it a bug ?
05-31-2018 03:52 AM
I found a workaround!
Use a network-shared array of strings instead and assign it to the property "List Items" of a List Box indicator:
Example code here:
Building an array of strings
the network-shared variable
converting an existing multi-line string into an array of strings (makes use of OpenG's Multi-line String to Array.vi which is part of the OpenG string lilbrary available via OpenG Library on LabVIEW Tools Network
06-04-2018 10:32 AM
thank you,
I'll test it, when it'll was possible![]()
03-26-2019 02:12 AM
there is screen difference between ipad and android tablet, both use different type of operating system, check your code again and did you use </br> line break tag?
03-26-2019 05:07 AM
Hey Richard,
Thank you for your additional input. As described in the first two posts, thib_fr had no problem with line breaks on Data Dashboard for Android. Only the iOS version was problematic (but a workaround exists, as I described).
I am not sure if your posting is a question or an additional suggestion.
I did not use any html tags on my code (should be <br /> by the way in xhtml, having the slash at the end). I don't own any apple hardware anymore, therefore cannot test if this would make a difference. My gut feeling however is that it does not.
I attached my demo project from a year ago to this posting, could be more handy than the snipped above. Disclaimer: It contains one OpenG VI.
